I wouldn't' keep driving it in this condition; it sounds like you have a water cooling system leak, if it is coming out on the passenger side of the engine, under the harmonic balancer/crank pulley, it is most likely your waterpump is leaking, needs replaced. If you keep driving a vehicle with a cooling system leak; it will eventually, cause engine damage and can cause a warped head, blown head gasket (thousands in repair costs).
If you are unable to do this type of work yourself; I recommend, you have the vehicle towed to a shop that specializes in VW's or a repair shop you trust. Typically, a cooling system pressure test; will help identify, the source of the leak and then, appropriate replacement parts and repairs, should be done.
