241 - 260 of 271 Posts
I don't know if the 1.6L is the same or uses a similar fan or thermostat setup (two fans, dual speed); the above info is listed for the: 1.9L TDI, 2.0L and 1.8T gas engines.
My guess would be it is possible they are very similar or the same; also, VW tends to use similar parts and possibly specs, in their platforms, in this case the Mark IV platform (Golf, Jetta, New Beetle).
2006 1.6 Beetle Luna Cabriolet
Discussion Starter · #244 ·
Huh there's a lot of variation but ive never had it hotter than 93. least i know its flowing around. test ride tomorrow. reversed it into drive today and went really well. lol. the 1.6L has a single fan but has housing for 2!
Discussion Starter · #250 ·
I assume 1.6 were not sold in states and only Europe where its cooler and generally dont need a 2nd fan
253176
Ok, always good to confirm things; I asked, as there was a "blank" hole, you were running hot and I worked on a Jetta 1.8T one time, some just removed the fan, it was gone! Based, upon my own New Beetle 1.8T, I think VW does do some "localization" modifications; based upon the climate of the delivery area of the vehicle. My car, for example: had a "hot weather package" on the option codes; listed, when I decoded the vin number one time and I wouldn't be surprised, if your car was delivered to a hotter climate, VW may have added a second fan, to help keep it cool. My 1.8T, also has a electric auxiliary coolant pump; that runs, circulating coolant to turbocharger, to keep it cool and runs for awhile, after you shut the engine off.
Discussion Starter · #259 ·
Well Mr Billy, With your guidance and assistance and my Too-dumb-too-quit attitude, we have finally fixed one smoking 1.6L Luna Beetle Cabriolet, Took her for a 20 mile drive today breaking in the rings as instructed. Purrs lovely, I think the ECU has to settle down everything a tad but idles lovely! drives like a new car! no sounds, no smoke! No overheating, was running 89-90c when driving about. No smoke in traffic. and the coolant comes up to the max line on bottle when hot, PERFECT.
So to fix your 1.6L smoking, all u need to do is a full engine rebuild and get a new battery and exhaust. Thanks and goodnight...(jk)
But yes, my issue was the OIL RINGS being seized and not turning separately and a busted CAT pipe. (Possibly caused by a faulty thermostat making the engine too cool and fouling the rings)
You don't need many specialist tools to do this on your bug, and if you're somewhat handy with them i recommend getting a Haynes manual and saving yourself a grand in garage bills.
Handy tip: YOU CAN TAKE CYLINDER HEAD OFF WITHOUT TOUCHING THE VALVES OR CAMS MEANING U DONT HAVE TO MESS AROUND WITH ENGINE MOUNTS, I RECOMEND A BENDABLE INSPECTION MIRROR AND CIRCLIP PLIERS TO ADJUST THE TIMING TENSIONER IF YOU USE THIS SILVERGRIFFIN21 CHEAT. But u might as well replace the valve steam seals and re-grind the valves while the head is off....might as well..right?
Things I have replaced:
  • Valve stem seals
  • Piston rings
  • CAT pipe
  • Cylinder head gasket
  • Battery
  • Intake manifold gasket (upper and bottom)
  • Valve cover
  • Oil
  • Spark Plugs
  • Coolant
  • Coolant flange sensor
  • Thermostat
Things I fixed:
  • Brake booster vacuum hose
  • Stripped TB bolt
  • Bore honing
Things I HAD fixed:
- Cylinder head re-surfacing
