1 - 1 of 1 Posts
Tracking down 6A battery drain. Multimeter measured inline.
Pulled every fuse and relay, no change to drain.
Drain is on the second fuse line from left at battery. This line goes directly to relay panel, post number 500 I believe. Today I pulled all relay panel wires at bottom, and the “30” post number 501 has the current.
I looked for wiring diagrams and couldn’t find anything useful.
There are two red wires attached to post 501 (constant 12V) on bottom of relay panel, and I really need to know what they connect to. The current is actually 5.7 Amps if that helps. Any and all ideas and help will be greatly appreciated.
Thank you in advance,
Tod
1 - 1 of 1 Posts
