MY daughter's 2006 NB Coupe was vandalized this week. The antenna mast ripped off (missing) and the antenna base was broken too. The base still has all the "guts" in it, but no place to screw in the mast.
With your help in this forum , I removed the old base - Two main wires - black "co-ax" and yellow with an off white plastic connector. What does each wire do? Am I correct to assume the co-ax is for AM/FM? The yellow- Satellite? Or something else?
Local dealer wants approx. $150 for a OE base and the mast. Thinking about going aftermarket - Maybe sharkfin? She does not use the satellite. Any suggestions for product here? Do I only need to connect the black co-ax to a "new" antenna? Does the old antena base have any value to anyone?
