I'm in the market for a complete set of interior panels for my 2006 NB convertible. Preferably black, but I will consider other color combinations. Hardware is not required, but I will consider all options with or without these items.
Would you post a picture of you repaired panels? I’d like to see what’s possible. My driver side panel is pretty embarrassing. I have a makeshift card board insert under the fabric until I can get it to a upholstery shop. It’s pretty sad. Passenger is still in ok shape. The electronics in the driver door are not the greatest either. Door locks don’t work from the inside and the window regulator requires prompting to work. I know it sounds like I’m gripping but I’m really not. It’s just quirks I’ve gotten used to dealing with on a car I really love.Cost effectiveness, is always a issue; that is why, i ended up repairing mine; because of this. they turned out well; one has to decide, what is the best way to go.
I ended up buying used broken door panels at a local, pick/pull and was able to cannibalize good used parts, ending up with two good panels out of all the four broken ones.
If you have photos, of the panel damage; post them up, for us to see. Plastic panel repairs are possible or replacing bad parts with new or good used, is a viable solution.
