1 - 1 of 1 Posts
Okay, I posted this in the 2.5 section but thought I would bring it over here in the hopes someone can help.
2006 NBC with 2.5 auto transmission.
Runs fine for about an hour to hour and a half. Then last week it would lose rpms for about 10 seconds and then recover. This happened with the cruise off and on at highway speeds.
This week same symptoms after 1 hour of driving but now it is doing the losing rpms thing every 30 seconds to a minute or so. Additionally now it is stalling at red lights. Started right back up but continued to sporadically lose rpms/power and then surge back.
NO CHECK ENGINE LIGHT WHATSOEVER.
I have checked electrical connections and vacuum and airbox connections under the hood, but have not found anything lose or damaged.
I have heard about possible transmission problems, the MAF sensor(i still need to get the security torx to remove and clean), ignition coils, spark plugs and fuel filter.
I am reluctant to remove ignition coils because the d#%N things look like the tops are all plastic and will break if you look sideways at them, much less start tugging on one.
Any suggestions?
Anyone have a homemade tool that can remove the ignition coils?
Help!
1 - 1 of 1 Posts
