RAYBESTOS 96778FZN (Fully Coated (Maximum Protection For Rust Prone Areas)) Element3; Coated
Front; With 280mm Diameter Rotor (2) $50
MOOG LK008 (Standard Replacement) Includes Snap Ring, Bearing, Knuckle, Hub Assembly, Backing Plate, Backing Plate Mounting Bolts, and Axle Nut
Front Right; With Integral Caliper Bracket; with 280mm Rotors $160
MOOG LK007 (Standard Replacement) Includes Snap Ring, Bearing, Knuckle, Hub Assembly, Backing Plate, Backing Plate Mounting Bolts, and Axle Nut
Front Left; With Integral Caliper Bracket; with 280mm Rotors $160
WAGNER QC768A (Daily Driver) ThermoQuiet; Ceramic
Front; with 280mm Diameter Rotor; with Electronic Disc Brake Pad Wear Sensor(s) $30
