Just picked up a 2007 Beetle hardtop. Came with a broken antenna and the shop said would be $300 for the part. The car has the satellite option. Can anyone shed light on the antenna and what cheaper/better option there may be available. Not sure if this was a blade or rod antenna since the top part is broken off.
The attenna on a satelitte radio has the receiver built into it. It is a small dome attenna base and they are expensive to replace. What is broken on yours? If it is just the mast and the threads are good in the anttena base a new mast will fix it.
