2008 Bettle -Driver side Roof leak
487 Views 4 Replies 3 Participants Last post by  billymade
Hi everyone. There has been an apparent leak on the driver side of the car right underneath where the drain hose terminates. I tried to stick a smaller size hose all the way down from the top of the moonroof entry. The issue now is that’s when I tested by dropping water from the top it drips immediately from the top side. Is there a connection on top that I may have disconnected? If so what do you guys suggest I should do as far as try to reconnect it?
Update. The headliner had to be replaced so the ppl who did it also blew the hose with an air pressure machine; hopefully that solved the issue .
There is a connection on top that can get disconnected.
  • Like
Reactions: 1
When the headliner was removed I checked the connections to make sure they were not undone as I had fed a smaller tuve yo clear any dirt . The connections at the top of both sides were good .
253042
One video, shows the owners; adding a bit of silicone sealer to the connections, could be a bit of insurance, so they don't fall off or leak?
  • Like
Reactions: 1
