well done with sway bar and no ECU/flash/ tune since this 2.5 being naturally aspirated.
so on two the headlights: I went with LED bulbs
I did both bulbs on the drivers side:
low beam
As you can see the light is much brighter
High beam
low beam
High Beam
Toyuki H7 LED Headlight Bulb, H7 LED Bulb 6000K 8 CSP Chip Extremely Bright H7 Headlight Bulb Conversion Kit Halogen Replacement, 1:1 Size Plug and Play No Adapter Required, Quick Installation
now order them for the passenger side.
oh FYI...not sure if you have ever done bulbs installation but use a 9v battery this will power on your headlight with minimal power.
Just attached the headlight light prongs ( both of them) to a wires and them touch them to 9V battery and light it for 5 second and do this 5 times it helps the bulbs with the power on
low beam
High beam
low beam
High Beam
Amazon.com: Toyuki H7 LED Headlight Bulb, H7 LED Bulb 6000K 8 CSP Chip Extremely Bright H7 Headlight Bulb Conversion Kit Halogen Replacement, 1:1 Size Plug and Play No Adapter Required, Quick Installation : Automotive
Buy Toyuki H7 LED Headlight Bulb, H7 LED Bulb 6000K 8 CSP Chip Extremely Bright H7 Headlight Bulb Conversion Kit Halogen Replacement, 1:1 Size Plug and Play No Adapter Required, Quick Installation: Headlight Bulbs - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
