Hello I just purchased a r tittled beetle that was wrecked I fixed it up but I just recently had it scanned and recently the oil Light has came on for the oil pressure i'm not sure if from what the scan says the oil pressure sensor is bad or what but I am posting the scan below if someone can help me so I don't damage the car from driving it with bad oil pressure
VIN: 3VWJP7AT1CM613793 License Plate:
Mileage: 104930km-65200mi Repair Order:
Chassis Type: AT (6N0)
Scan: 01 02 03 08 09 15 17 19 25 2E 56 77
Mileage: 104930km-65200miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 1010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 E HW: 07K 907 309 B
Component: 2,5l R5/4V G01 1154
Revision: T4H06--- Serial number:
Coding: 0000075
Shop #: WSC 00066 000 00000
VCID: 3064869EA36556C159-8064
7 Faults Found:
005709 - Oil Pressure Switch for reduced Oil Pressure
P164D - 000 - Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 232
Reset counter: 255
Mileage: 97003 km
Time Indication: 0
Date: 2016.01.21
Time: 09:00:52
Freeze Frame:
RPM: 2692 /min
Load: 81.5 %
Speed: 50.0 km/h
Temperature: 39.0°C
Temperature: -1.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.478 V
012408 - Throttle Control
P3078 - 000 - Airflow at Idle too Low - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 101682 km
Time Indication: 0
Date: 2016.05.18
Time: 06:29:35
Freeze Frame:
RPM: 676 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 90.0°C
Temperature: 55.0°C
Voltage: 13.843 V
005707 - Oil Pressure Switch
P164B - 000 - Malfunction - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 101682 km
Time Indication: 0
Date: 2016.05.18
Time: 06:29:35
005641 - Crash Shut-Down Activated
P1609 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 104553 km
Time Indication: 0
Date: 2016.06.23
Time: 09:22:37
Freeze Frame:
RPM: 839 /min
Load: 17.6 %
Temperature: 84.0°C
Temperature: 45.0°C
Voltage: 12.446 V
001674 - ECM Power Relay Load Circuit
P068A - 000 - Opens Too Early - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 104553 km
Time Indication: 0
Date: 2016.06.23
Time: 09
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 92.0°C
Temperature: 41.0°C
Absolute Pres.: 980.0 mbar
Voltage: 11.938 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09G-927-750.clb
Part No SW: 09G 927 750 LG HW: 09G 927 750 LG
Component: AQ 250 6F 2042
Revision: 00H97000 Serial number:
Coding: 0000840
VCID: 0102135A584F0F49E6-8054
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: E14B4016492308FD871202ED921C1061A70000
VCID: 7BFE61B2FAA36599BC-802E
6 Faults Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 10
Reset counter: 219
Mileage: 99741 km
Time Indication: 0
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 16401
Count: 50177
Count: 0
Count: 250
Count: 0
01164 - ESP Operation
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 219
Mileage: 99741 km
Time Indication: 0
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 4
Reset counter: 227
Mileage: 104272 km
Time Indication: 0
Date: 2016.06.16
Time: 00:18:19
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 8193
Count: 50434
Count: 0
Count: 252
Count: 0
01321 - Control Module for Airbags (J234)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 227
Mileage: 104272 km
Time Indication: 0
Date: 2016.06.16
Time: 00:18:19
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 AL HW: 5C0 820 047 AL
Component: J301 Klimaanlage 0203
Revision: 2001109S Serial number: 00000000621100
VCID: 6AD054F64539EC1157-803E
1 Fault Found:
00818 - Sensor for Evaporator Outlet Temperature (G263)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 225
Mileage: 104722 km
Time Indication: 0
Date: 2017.03.09
Time: 22:00:44
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 E HW: 5C0 937 087 A
Component: BCM25 JLB H3 H66 0251
Revision: B2066001 Serial number: 04371274110409
Coding: 3BBC2918088B080000A02800240D84C400C2402F60000000B20004000000
VCID: 2F6685E27E5B493940-807A
Subsystem 1 - Part No SW: 6R0 959 801 AP HW: 6R
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 E HW: 5C0 959
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5C5 920 950 B HW: 5C5 920 950 B
Component: KOMBI H09 0019
Revision: X0009005 Serial number:
Coding: 250A01
Shop #: WSC 00066 000 00125
ASAM Dataset: EV_KombiUDSMM9RM10 A04305
ROD: EV_KombiUDSMM9RM10_VW32.rod
VCID: 28546EFE53B51E0181-807C
1 Fault Found:
12669184 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 228
Mileage: 104936 km
Date: 2017.03.19
Time: 22:34:07
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H66 0251
Revision: B2066001
Coding: 402000
VCID: 70E4469EA3E516C119-8024
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 228
Mileage: 104936 km
Time Indication: 0
Date: 2017.03.19
Time: 22:34:05
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5C5 920 950 B
Component: IMMO H09 0019
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ImmoUDSMM9RM10 A01301
ROD: EV_ImmoUDSMM9RM10_VW21.rod
VCID: 6AD054F68D39EC1157-803E
No fault code found.
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660697962
Coding: 010000
VCID: 29526BFA40BF27099E-807C
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 164 D HW: 1K0 035 164 D
Component: LOW NAR H02 0004
Revision: -----03S Serial number: VWZ4Z6L3211080
Coding: 01000400040002
VCID: 234E79D22293FD59D4-8076
1 Fault Found:
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 188
Mileage: 104936 km
Time Indication: 0
Date: 2017.03.19
Time: 22:37:12
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007660494012
Coding: 0A10040000010100
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 356AB78A940773E90A-8060
End-------------------------(Elapsed Time: 01:50)--------------------------
Address 17: DTCs cleared
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Discussion Starter #2
Any help would be greatly appreciated i'm really trying to get my car up and running also any insight with the other codes would be great too thank you very much
Hey, you have a number of trouble codes; that aren't coming up on the typical websites with the definitions of vw specific codes.
bentley: VW Online Technical Library - Diagnostic Trouble Codes (DTC) Tables
ross tech wiki: Category:Fault Codes - Ross-Tech Wiki
Which scan tool are you using? Some of the Chinese VW scan tools; will give trouble codes, that are gibberish or do not give specific info that is searchable with VW factory definitions.
One variable, that would be out of the ordinary; is the fact, that the car has been in a accident. It sounds like these later model cars; have a feature that kills the ignition in a crash (note: 005641 - Crash Shut-Down Activated _) and the airbag, may have deployed? Damaged components or disconnected parts; could also throw codes.
Keep in mind: trouble codes tend to build up over time and are not erased from the ecu memory, until cleared using a scan tool or hard reset.
I have seen situations where many codes will be present but happened because of issues in the past or because of parts being removed, battery changed, etc., when the key was on. You might start, by clearing all of your codes and see if any come back, when starting the car or going for a short test drive.
IF the oil pressure light; comes on, during your test drive. Then, I would start troubleshooting that issue; unfortunately, we do not have any manuals to help point you in the direction of a testing process. As of this time; only professional online service manual sources (e.g. VW ERWIN, ALLDATA, MITCHELL1, etc); are available, for reference. As 2017, no one has published a paper service manual; although VW's ERWIN online service; can be purchased for one day @ $35 and you can download the manual in .pdf format and save them to your computer, to refer to later.
https://erwin.vw.com/erwin/showOrderFlatrate.do
Here are some codes; that I did find:
19534 - Ross-Tech Wiki
OBDII diagnostics. Trouble code definition for code P164B. Causes of error P164B
01314 - Ross-Tech Wiki
18017/P1609/005641 - Ross-Tech Wiki
P068A/001674 - Ross-Tech Wiki
01164 - Ross-Tech Wiki
02214 - Ross-Tech Wiki
01321 - Ross-Tech Wiki
other codes; not found:
U1111 00 [008] - -
011 - Open Circuit
My beetle was wrecked when I purchased it I just finished fixing it. When I was driving it the car was running fine no problem the oil level is okay. Then I was about the park the car and the check engine light came on and I drove it for another 30 mins and the oil pressure light came on and started blinking and went off
Well, because of how crucial oil pressure is to the life of your engine; you might pull, the oil pressure sending unit/switch and hook up a mechanical oil pressure test gauge to it. You can check the pressure and zip tie it to your windshield wiper and that way, you can see it and drive around, to try to replicate the conditions, that it came on before.
As i mentioned before; what scan tool are you using? i would also clear the trouble codes and see if any come back.
I would go ahead and spend the $35 to subscribe to vw's erwin manuals for one day and download them. Then you can follow vw's testing procedures and see the oil pressure specs.
