Hey all,
I rebuilt the 1.8 in my sister 2000 GLX after it spun a bunch of bearings. She got a new car and now it is mine. For some reason the auto just didn't work when i reinstalled everything so instead of fighting it I said screw it and found a great deal on a low mileage DZQ 02J. I also live close to a junk yard with lots of VWs and low prices.
I am in the midst of the swap and still need to get a couple things. First is a late MK4 shift box and shift tower. My trans has the old style 02A tower. second is axles, and finally clutch pedal.
Here are my questions:
1: i read that you can just reuse the auto engine spacer instead of getting a manual one. Is this true?
2. Are all mk4 clutch pedals and master cylinders the same? My junk yard has a great condition pedal with a brand new master on it but its not from a bettle
3. I know gasser starters wont work in a TDI but will a TDI starter work in a gasser?
4. The DZQ is a 2.0 transmission which means different axle flanges i believe. Is it true I can swap my 1.8 cups onto the trans and just reuse my auto axles?
Thank you everyone in advance
Hey all,
I've done a 5-speed swap on my 1.8t almost a year ago. Here's the answers from my perspective:
If you're referring to the dust plate, the answer is no. You could, but there's a hole in the auto plate that will get dust into your clutch area- not good.
The master cylinders are the same. If you look at your current master cylinder, theres an extra tube, protruding out of the master cylinder- this tube is crimped at the end. That tube is your clutch feed. You'll have to cut the crimped end off and attach a supply line.
The clutch pedals are the same. Our cars to some degree have a standard platform to work with i.e. parts/positions to accommodate auto and manual transmissions. Take the manual pedal and mounting brackets off the manual car and put them on the auto car.
Not sure about this one. For me, i found it best to go new and save any aggravation of replacing a short-term starter. If you're doing a swap, best to go all in and do it right.
The gearing is different in the 2.0 transmissions as well. You're best to find a 1.8t transmission, especially one that's mated to your engine code. car-partDOTcom has great prices on transmissions and can locate one for you via their part finder.
Hope this helps you out. I'm prepping to go out of town for a few days, but i'll share more info on my swap when I get back in town.
All the best.
