Supplies Needed: Taken directly from the "White Paper"
Flywheel, Clutch, Pressure Plate, Throwout bearing, we recommend a quality balanced flywheel
5 speed dust shield for the engine DO NOT REUSE THE AUTOMATIC SHIELD
5 speed transmission (EBJ, EGR codes)check your engine for proper manual trans. code
Starter
Axles
New axle nuts, seals, and bolts
Clutch pedal, plus both brackets, both switches
Dieselgeek TTX Short Shifter or Sigma 5 Short Shifter
5 speed power steering line and G 000 002 fluid (optional)
Stick shift box and cables and ends
Coolant Hose Coupler
"53" relay
Electrical Butt Connectors/heat shrink
Gaffers tape, chaffe tape, harness tape, DO NOT use general electrical tape
G12 Coolant
PB Blaster
Common Part Numbers:
Small Clip on Master cylinder - 7M0 721 431
O ring for master cylinder - 02F 141 143 A
350mm Hose to Hydraulic Tank - 857 721 453
Clutch pedal firewall gasket - 1j1 721 410
3 M8 Nuts that hold clutch pedal in N - 902 264 03
Transmission dust cover plate (manual) 06a 103 645 m
Engine dust cover plate (manual) 06a 103 645
Axle Bolts x12 (ask the dealer)
Transmission bolts there's four of them, two different sizes (ask the dealer)
53 relay (very common in VW's... just look around)
a bunch of butt connectors
AXLES
1 Axle Left 1J0 407 271 H
1 Axle Right 1J0 407 452 X
8 Bolts 893 407 237
6 Spacer plates 1J0 407 357 A
2 Locking Nuts N 905 876 02
TRANSMISSION
1 EGR coded trans 02J300047M
TRANSMISSION FLUID
2.0 Liters G 052726A2
TRANSMISSION BOLTS
1 Top Bolt Rear N 10337803
1 Top Bolt Front N 90701604
3 Oil Pan Bolt N 90870401
1 Bottom Rear Bolt N 10337803
2 Starter Bolt N 90766202
TRANSMISSION LEVER
1 Shifter Assembly
1 Knob Assembly 1J0711113BB
2 Lock Washer 1J0711280B
2 Bushing for up down 1J0711067L
CLUTCH PEDAL
1 Clutch Pedal Assembly
1 Bracket 1J1721379B
1 Bracket Cruise unknown
1 Clutch Hose 1J1721465AL
1 Slave Cylinder 1J0721261H
2 Salve cyl bolts N 0103324
5 clutch pedal bolts N 90226403
CLUTCH SHEILD
Main Part 06A103645
Axle releif 068103645M
Bolt N 0102085
spring washer N 0122265
STARTER
1 Bosch 02A911024DX
CLUTCH
1 SMF Valeo G60 VR6 Kit
includes all bolts, flywheel pressure plate, cltutch, throwout bearing
ELECTRICAL
1 '53' relay
8 pink crimps
Clutch Switch Cruise 1J0 927 189 E
Switch Cruise Connector 6N0 972 704 D
Clutch Switch Starter 1J0 927 189 C
Switch Start Connector 1J0 972 702
Reverse switch 02K 945 415 C
Rev switch connector 1J0 973 702
SPECIAL PARTS
1 modified bracket
1 short shifter
Tools Needed
Hose clamp pliars
Electrical crimp tool
Heat gun
Engine support beam
Transmission Jack
T20 Torx driver/bit
T25 Torx driver/bit
T30 Torx driver/bit
M10 Triplesquare bit
M8 Triplesquare bit
Misc 1/4" and 3/8" extensions
10mm 1/4", 3/8" Deep Socket
13mm 3/8" Deep Socket
15mm 3/8" Socket
16mm 3/8", 1/2" Deep Socket
18mm 3/8", 1/2" Deep Socket
Starter
Axles
"53" relay
G12 Coolant
PB Blaster
AXLES
8 Bolts 893 407 237
TRANSMISSION
TRANSMISSION FLUID
TRANSMISSION BOLTS
TRANSMISSION LEVER
1 Shifter Assembly
CLUTCH PEDAL
CLUTCH SHEILD
Main Part 06A103645
Bolt N 0102085
STARTER
1 Bosch 02A911024DX
CLUTCH
ELECTRICAL
1 '53' relay
8 pink crimps
SPECIAL PARTS
1 modified bracket
1 short shifter
Tools Needed
Hose clamp pliars
Heat gun
Engine support beam
Transmission Jack
T20 Torx driver/bit
T25 Torx driver/bit
T30 Torx driver/bit
M8 Triplesquare bit
15mm 3/8" Socket
