OK, this is a list of all the 502.00 and 505.01-approved oils available worldwide. This should alleviate any question or concern about what oil to run in your PD.
you need the 505.01 oil in your 06 tdi not the 505.00.-1- said:Great information. I have a new 2006 NewBeetle TDI. I've started checking and can't find the 502 & 505 spec oil anywhere. Besides the dealer, where is it available in the USA?
tdi jerry said:you need the 505.01 oil in your 06 tdi not the 505.00.![]()
No, but I'll buy it off you for use in my VR6.-1- said:I'm confused. I have several cases of Castrol Syntec, SAE 5W-40 Full synthetic motor oil. VW 502.00, 505.00. "Offers full synthetic performance, engineered specifically to meet the Volkswagen engine warranty requirements including testing in VW TDI engines". Can I used this oil in my 2006 VW TDI?
The Cheat said:No, but I'll buy it off you for use in my VR6.
You can get 505.01 in bulk from ecstuning.com.
The dealer that I have my oil change uses the oil you described above. It has worked for 15000 miles so far.-1- said:I'm confused. I have several cases of Castrol Syntec, SAE 5W-40 Full synthetic motor oil. VW 502.00, 505.00. "Offers full synthetic performance, engineered specifically to meet the Volkswagen engine warranty requirements including testing in VW TDI engines". Can I used this oil in my 2006 VW TDI?
