Here's my story bought a 05 convertible with the 6spd auto/stick tranny with the transmission pan hit by something that broke half of the valve body mounts. Found a used HFZ tranny on Craiglist and installed it without changing the torque converter seal(didn't even think about it). Well she was leaking fluid so I took the tranny out again and changed the seal that I bought from VW (same numbers that was on the old seal) put her back in and again she is pouring fluid. So I said maybe the torque converter has a problem that came with the tranny. So I pulled the tranny again and pressure tested it and it held fine. I looked at the converter bushing in the oil pump and the copper had pieces missing and you could turn it by hand so I removed the one from the trashed tranny she looked almost new so I pressed her in then installed a new seal again. I looked at the torque converter and it had some damage on the shaft where the seal rides so now I am thinking got the problem solved by using the torque converter from the trashed tranny as well. Put it back in the car and F M the fluid is still pouring out.
Since you can't see behind the torque converter I am at a loss, if anyone had a similar problem and has a cure please let me know. Can the oil pump o-ring behind the tranny case be causing the leak? Again I am at a loss I measured the distance from the flex plate to the engine block and it is within tolerance (no wobble I could see when the engine was running)Does anyone have the specs on the converter shaft so I can compare it with mine? Any help would be appreciated....
