So I recently upgraded the Monsoon head unit in my 2003 NBC from a tape player to the newer CD player that supports MP3 and Sat.
I already had the 6 disc changer in the console.
I was surprised to see the newer head unit had an Aux function on the display. I started looking around for cables and found very little useful information.
Many people purchased aftermarket interface boxes that appear to go in place of the CD changer. All the cables I found were the blue 8 pin connector.
Well after a lot of looking around and studying the new head unit, it appears that it had a 6 pin connector that supported Aux input.
Then I realized that the connector in the car actually had the spare Green and Yellow 6 pin connectors that marry up with the blue connector to make up the entire plug that goes into the head unit.
Well I decided to purchase one of the Aux cables on ebay that had the 8 pin blue connector. I figured this would not work, but all I really wanted was the wiring with the terminals installed.
Well the package came today. I played around trying to figure out how to release the small terminals from the blue connector, could not get anywhere fast enough, so I decided to carefully cut the blue connector so I could release the terminals.
Once I had the terminals out, 15 minutes later I had them plugged in to the existing green connector in the car and had a working Aux input!!
Pandora, tunes on my Droid, awesome!!!
Now the next project is the new OEM Sirius module I picked up for $50, this will be a bit tougher, but I will get this sorted. Very similar to the 2 BMW's that I added factory Sirius in.
So for anyone with a newer head unit, not sure the older ones will support the Aux input, you can get your Aux working for under $10.
Now I am going to look into a Bluetooth A2DP interface so I will not need a cable at all!
The other thing I want to do it tie into the glovebox light (only works with the ignition on) and use this to drive a relay that will allow me to switch the lighter socket to on all the time or on only with ignition!
