I have a 2003 1.8L Turbo beetle that's giving me all kinds of fits !! ECU& ASR lights come on and the car starts acting like it is possessed !! It goes into limp mode, idles irratic, brakes are very very hard to stop. After I turn the ignition off and on again the warning lights go out and the car drives perfectly. After about 10 miles the lights come back on and when I slow down to stop the car shuts off. After starting again car runs better than it has ran since I've had it but I hear a roar and the car speeds up on its own. The codes are P0300,P0420,P0411,P2181,P0221,P0301,P0302,P0303. I am at a lost right now so any help will be greatly appreciated.
16684/P0300/000768 - Ross-Tech Wiki
16685/P0301/000769 - Ross-Tech Wiki
16686/P0302/000770 - Ross-Tech Wiki
16687/P0303/000771 - Ross-Tech Wiki
The above codes; are all misfire related.
16804/P0420/001056 - Ross-Tech Wiki
16795/P0411/001041 - Ross-Tech Wiki
18613/P2181/008577 - Ross-Tech Wiki
16605/P0221/000545 - Ross-Tech Wiki This problem; is most likely, what is causing your drivability problems.
A good thread; discussing, a members process of fixing his throttle body related trouble codes:
http://newbeetle.org/forums/1-8-lit...-actuator-body-rough-idle-issue-resolved.html\
Brakes:
The issue are referring to; could be related to the vacuum hoses connected to the brake booster or a failed brake booster itself. A very common problem; is the vacuum hose connected to the brake booster cracks and leaks vacuum or disconnects from the connection. Other hoses coming from the booster; have valves, make sure they are not broken or leaking.
