Im working on a friends beetle that is full of issues from the PO. The passenger window was caulked up in place :wtf:, pulled the door panel to discover a lack of a window motor. Easy fix right? wrong. Installed a used motor and when plugged in neither side works. Its not the circuit breaker, I tested each side individually and either side works independently. with the pass side motor unplugged i read pin6 - 1.73v, pin15 - 3.29v, pin19 - 12.30v, and pin20 - 12.20v at the connector with the key off. I get the same with the key on.
with both motors plugged in the system shorts and it is not the breaker behind the kick panel. I read pin6 - 0v, pin15 - 3.29v, pin19 - 12.29v, pin20 - 12.29v pass side on the motor connector.
is this a common issue? I did read in some thread i found on google that it could be a break in the harness... ok thats nice to know but thats not helping any.
