[Update] 99 2.0L Possible CCM Failure?
I'm having some power window, door lock issues. I have troubleshot the switches for both the door locks and windows with a multimeter and they are functioning correctly.
Currently my issues are:
I have checked the following so far:
EDIT: Forgot to mention that I checked fuses 5, 6, 14, and 38. None blown but replaced them anyways.
- passenger side door does not light courtesy light when door is opened. Nor does Pxr ambient lighting work.
- Both windows and locks only works for about 10 minutes after connecting battery, then does not work.
- Passenger door locks will not work.
- Door lock button on drivers door only operates drivers lock.
- ohmed the door wiring harnesses and window and door lock switches - all good.
- Both switches on drivers door will operate the drivers window.
- Both window motors are good.
- I have dismantled the Passenger door locking unit and checked the soldering on the circuit board (all fine), as well as checked the functionality of all 4 microswitches inside (all fine).
