Hey, first I would scan the car for trouble codes.
The locks; automatically lock by themselves. That is normal.
Speedo issues; could be a failing cluster or a speed sensor failing. See if there are any trouble codes for the issue and you could run "output" tests in VCDS; to see if the speedo motors are bad. This will activate; a full "sweep" of the each of the needs/gauges.
Lack of power; could be a number of issues, (fuel, ignition, etc.). Please get those codes, post them up here and we will go from there.
How long have you had the car and how many miles are on it?
