So I have the open trunk light all the time which I'm pretty sure is due to moisture. Have read many places to clean and check the connections.
Can someone show me a picture of the switch? I have it all apart and cannot find it or even the wires running to it. Randomly when I goto start the car the alarm goes off so I'm guessing that's the issue as the door switches work fine. Latch itself in working properly other than last night I had to adjust the hinge screws because it decided all of a sudden to not line up (one adjustment screw was out twice what the other was)
Any help would be great.
Discussion Starter · #2 ·
So I ended up disconnecting the switch and stuff is working now for the most part. But how do you remove he plastic cover from the latch mechanism to spray it with contact cleaner? I can't figure it out.
