Ruby's master mechanic
Any ideas as to what causes this? I think I may need a new battery but the car starts fine and only stalls when the car is both put into neutral AND the A/C is on.
When I put the A/C on, the RPMs drop a bit and when I put it into neutral, they just drop out completely. This happens if I reverse the order as well and turn the A/C on after it is in neutral.
It may be happening more now that it is hot but that may also be a coincidence due to my using the air more often. It does not happen every time but its seems to be getting more and more frequent.
Super smart senior member
It could be a few things but most likely its your throttle body, specifically the motor that controls it (some call it the IAC but its different)
It could be bad which would require a replacement but most likely you just need a throttle body alignment, easy to do with a VAG. I would also recommend taking the TB off and giving it a good cleaning with some TB cleaner.
Thanks for the input. I hadn't thought of cleaning the TB and after doing some research on here, it seems fairly straightforward.
I do not have access to a VAG, could I just reset it but unhooking the battery or doing the method that involves putting the key "on"/but not started for a few minutes?
Got the battery checked again yesterday, two different shops, both said my battery is bad/replace immediately.
You would need a vag to calibrate the TB, in fact it is usually required when you disconnect the battery for any long period of time :)
You can buy one of those $10 ones off ebay and use the really old free rosstech software it comes with and do it just fine.
