Looking to sell my daily driven TDI new beetle. This car has served me very well for a long time, my father bought it new off the lot and I bought it from him. It's been commuter for its whole life and has 274,000 on it (if you know tdi's there is still lots of life for this motor). It's the most reliable car I have ever had and is still a blast to drive. It's got a handful of mods on it but still get 35-40mpg depending on how you drive it!! Just got it smoged and registration payed up, so it's ready to be transferred to the new owner.
Here is a list of things about the car.
-Kerma tdi stage 2 tune
-Bosio PP764 nozzles on kerma calibrated injectors with stage 2 flow
-Kerma tdi 2.5" j downpipe to straight pipe exhaust
-franko6 stage 2 camshaft
-spec 6 puck stage 3 clutch with 14lb flywheel (a few months old)
-poly motor, transmission, dog bone mounts
-poly bushings all around
-rsk coilovers
-kyb AGX adjustable shock in rear
-solid subframe bushings
- audi tt steering rack (has a shorter lock to lock ratio then the stock one)
- poly steering rack bushing
-raceland adjustable sway bar end links
-h&r 26mm front swaybar
-neuspeed 28mm rear swaybar (with new install package about 3 months ago)
-b&m short shifter (shortens front to back)
-gruven Parts Quick Shift Bracket (shortens side to side)
-full gauges on dash (boost, water temp, oil pressure, exhaust temp)
-18" 1000 miglia wheels with gt radial champiro uhp1 tires
-suspension/steering went though recently new ( inner and out tie rod, ball joints, wheel bearings, rear swing arm bushings, inner/outer CV joints, wheel bearing in driver side)
-new coolant and reservoir
-new coolant
-new thermostat
-glow plugs a few months ago
-new battery
-new redline transmission fluid (added a magnetic drain plug)
-new ATE super blue break fluid
-Full emissions delete ( but done stealth so it passes smog no problem) still have all the parts if you want to put it back.
-new starter
-new alternator
-new clutch master cylinder
-new air filter
The bad
- paint is faded and kinda beat up.
- key fob died
- hood is slightly bent from popping up on the freeway. Has new hinges.
-AC delete (compressor died so i did it to save the weight, still have all the hoses)
-drivers seat shows wear and has a small tear.
Asking $3700 Email with any questions picture in add http://losangeles.craigslist.org/sfv/cto/5624986735.html
