I need help, Attached is a picture of the item mounted atop of the Auto-trans and its leaking oil. I've looked thru the repair manual[haynes] and in parts listings online and i don't know how to define the part.
That electrical connection is on top of the speed sensor.
Is the oil coming up the sensor and through the connector? Or is it dripping on the connector and the top of the transmission from some other line?
Yes, its seems to be coming up thru the sensor. Also thanks, now i know that its the speed sensor. Also, is it possible for that to happen? due to the location i used my cell to take pics from all sides. Another question is, can this cause the odometer to fluctuate the speed at which the vehicle is traveling?
