I just made a thread with the same issues as you! The AC fuse burned out, and partially melted the fuse junction slot. I replaced the fuse and it worked fine for a few days before quitting.
In my situation, the fans work so that means the fuse is providing power, but I tested the connector coming off the AC clutch and it is reading 9 volts even with the key off. I'm thinking my AC clutch is burned out because my AC relay is stuck closed. Test the 2-pin connector going to your AC clutch and see if its getting power.
Also try this, with the AC off, start the car, then have someone watch the AC clutch when you press the AC button inside. It should turn on for a second, then turn off. If it doesn't, there may be something wrong with the electrical system (like the AC relay). If it does turn on, then shut off, the pressure is too low and the compressor is being turned off by the AC cutoff switch (could also be faulty).
