Hi everyone,
I'm looking to do an AC delete on my 2002 Turbo S. I have searched high and low, but can't find much info. Found the AC bypass pulley in another thread but reviews are mixed and no info if it works for AWP motors.
Would like to keep power steering.
Any help is appreciated.
Thank you
Edit: want to remove all AC components. I'm gutting the car as much as possible and will not need AC.
Don’t confuse the timing belt with the serpentine belt. The timing belt stays the same. It looks to me as if you use that ac compressor replacement the serpentine belt would be the same also.
I have confused the two. Thank you for your help
