1 - 1 of 1 Posts
I'm not sure if Anyone is aware but I've found a few threads about the light not working and led bulbs wont work... here's a bit of info.. the ac control switch light is behind the fan control knob.. its a #74 bulb.. this bulb can be replaced with a dealer item or parts store item but if you want an led it has to be a 360 degree led... you can find the led here...
Sorry if this is a repost.. just thought it'd help someone..
https://www.superbrightleds.com/moreinfo/subminiature-bulbs/74-led-bulb-3-smd-led-wide-angle-wedge-base/228/
1 - 1 of 1 Posts
