AC Issue - 2002 VW Turbo Beetle (not the S Model) – The symptoms are:
• Compressor isn’t coming on (BTW, I replaced the compressor/cluth last year, brand new Behr)
• No cold air and little electrical anomalies like erratic engine idle, or high engine idle, or an occasional sputter.
Here’s what works:
• I tested both cooling fans; they’re fine and operate together
• the 3 fuses on top of the battery tested okay too – additionally, I cleaned them with 320# and reseated them; also, I cleaned (the best I could) the contacts wherein those fuses seat.
• R134 checked okay
This may help the diagnosis:
A mechanic tested my new/1-year old Behr compressor; he says power is only getting to it intermittently. He pulled off the connector to the compressor, and put a probe in the socket (grounded to the negative battery terminal). The probe lights up for a split second, then goes dark for 4 or 5 seconds, then repeats)
Any thoughts?
Here’s what works:
• R134 checked okay
Any thoughts?
