1 - 13 of 13 Posts
OK so on my 00 I recovered the freon then vacuum and then did a leak test and it passed so I charged it up and here's my problem ac clutch turns on like normal but my air coming out the vents isn't cold as it should be but it isnt warm its like trying to cool but not cold. Any ideas or suggestions
Discussion Starter #8
Alright guys finally got a chance to hook it back up to the ac machine anyway here are the results
Ac off pressures. High side 90ish low side 90ish
Ac on pressures high side 70ish low side 70ish compressor clutch engaged
I recovered all freon from system and turned on the ac and compressor clutch does not engage.
Then I vacuum the system then ran a leak test and all good then recharged.
Anyway still no cold air I need help
It sure seems like it. But that is an expensive part. I would get a second opinion, before I put a compressor on it. It took me about 3 hours to put the compressor on mine, it was a lot of work.
Maybe do a Google search on compressor having the same pressure on both sides while cycling?
Sent from AutoGuide.com App
1 - 13 of 13 Posts
