pixelsrzen
Is this possible? Are the components bolt on? or would it involve major parts swappage?
Thanks in advance for any help you can provide.
strange things are afoot
yes it is doable.
no its not too difficult, (unless you also want to install the disable switch on the dash)
it requires finding the ABS valve body and brake lines between the MC and the ABS unit. then its pretty much plug N play..
there is a very good (read very long) thread on tdiclub all about it, including the addition of the ASR disable switch located :HERE
Best of luck.
I found out recently that my '98 doesn't even have ABS. I wonder how much it would cost to retrofit all the fancy electronic gizmos (and whether I should even want to)...?
