Not sure the differences in the years and rotor sizes so you do have to be careful you get the correct kit number. Another good source is AutoAnything.com they ship free. You could also to to Power Stop's web site and see all the other online dealers as well.
I actually ordered a set for my BMW 330cic today from Auto Anything as they were slightly cheaper than Amazon, but there was some question on the application. So I called Auto Anything and they contacted Power Stop and even Power Stop was a bit stumped on my specific application. I am waiting to hear back from Auto Anything on the final kit part number.
The Auto Anything guys have also had good things to say about the Power Stops.
I have a $3k Brembo kit on another BMW I have. Slotted rotors. Nice set up with 4 piston caliper and big long brake pads. The Brembo slotted rotors make a bit of a roar when you jump on the brakes hard at speed, pretty typical of slotted rotors, but the Power Stop slotted/cross drilled combo is a LOT quieter on the VW. Not sure if this is due to less slots, rubber caliper isolation or why, but much quieter than the $3k Brembo system.
I can say the VW did stop pretty good with OE brakes and at least on my car the OE would have likely lasted 100k miles, I changed them at 78k miles due to the car sitting and the rotors were very rusted up. I decided it was not worth spending the money on turning the rotors when I was able to install the entire kit for $275.
Here is a shot of the front rotors on the car with the $275 full Blauparts.com strut and shock kit! And this is with about 7500 miles on the brakes. If you catch that I am missing the metal anti rattle wire on the caliper, I just happened to take the picture before I put the wire back on the caliper, so it is there now, just not for the picture. Also for daily driving, not sure how long these Power Stop pads will last, but very little wear at 7500 miles. Also I usually find the slotted and drilled rotors tend to run much cooler than solids and will likely also extend the life for daily use. If you track ANYTHING, expect very accelerated brake wear. But this system seems to really work well, more expensive than bargain parts house Bendix or Wagner, but I think also a much better quality.
