Air bag access holes are square and are at 3 and 9 o'clock. I bent an old screwdriver with a torch leaving about 4 inches length to access the holes which must be vertical to get in front of the speedo to enter. Both access holes become rubber tubes about 1 inch inside the wheel and then turn OUTWARD. Putting a screwdriver straight in won't accomplish anything. The flat end must be turned a bit to follow the turns outward to reach the retainers at the bottom. The flat end must be VERTICAL and retainers then moved inward (screwdriver handle outward) to free the airbag.
