I definitely was not sure where to post this... I managed to make a boo-boo today when it was BAC and snowing out.. I wanted to close one of the air vents and managed to push the turny thing too far to the left.. making the turny thing break off from what it was connected to (like a catcher so that it would close the vent) So now the turny thing doesn't catch when I turn it...
Question is.. How do I fix it?
Outer vents or inner vents?
Inner vents have a shaft that connects to the back assembly and can be popped off - you'd need to take the entire center radio surround/vent assembly off to check and see if it isn't broken and just poped out of it's joint. This happened to mine a while back.
marvins_dad said:
Inner vents have a shaft that connects to the back assembly and can be popped off.
I can see the thing that connects to the back when I turn the thing around... How do you take the surrounding piece off to get to it?
