Hi I have a 2013 beetle and its throwing a b12251b code for the passenger mat sensor high resistance. I've had the mat sensor replaced was wondering if anyone has run into this problem.
What scan tool are you using? Have you confirmed the maf readings are in spec with with live data from a scan tool?
http://www.ross-tech.net/vag-com/advertising/DiagnosingA_MAF_TechTip.pdf
Can you double check the trouble code; that code doesn't seem like a typical obd or factory vw code.
Replacement maf sensors, should be Bosch; for them to work correctly, stay away from cheap aftermarket parts.
Give us more info and we can go from there. Thanks.
