hi all. this is my first post on this forum.
i have a 2000 vw nb auto. have issues with no communication.
with all modules plugged in, i have ABS light on, AirBag light on, oil light flashes, e-brake light flashs, tach doesnt work. And VSDS cant communicate with airbag module.
This is the auto scan.
Code:
Saturday,26,December,2015,12:30:14:49733
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
www.Ross-Tech.com
Mileage: 174930km-108696mi   Repair Order: dec26
Chassis Type: 1C - VW New Beetle (1998 > 2010)
Scan: 01 02 03 08 15 17 19 22 25 26 29 35 37 39 46 54 56 65 75
   Mileage: 174930km-108696miles
Address 17: Instruments        Labels: 1C0-920-xx0.lbl
   Part No: 1C0 920 801
   Component: KOMBI+WEGFAHRS. M73 V02
   Coding: 02312
   Shop #: WSC 00000
   VCID: 58BFD54AB8D12EFE69-4B00
   Subsystem 1 - Part No: Ident
   Component: Nr. Wegfahrs.:VWZ5Z0X5221496
   Ident.-Nr. Wegfahrs.:VWZ5Z0X5221496
4 Faults Found:
01314 - Engine Control Module
            49-00 - No Communications
01315 - Transmission Control Module
01316 - ABS Control Module
01321 - Control Module for Airbags (J234)
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    V022
   Coding: 00007
   Shop #: WSC 91487
   VCID: 70EF8DEA306156BE81-4AE8
4 Faults Found:
Address 46: Central Conv.        Labels: 1J0-959-799.lbl
   Part No: 1J0 959 799 AJ
   Component: 5X Zentral-SG Komf. 0001
   Coding: 00257
   Shop #: WSC 00066
   VCID: 0603CB3222E5680E4B-4B00
   Subsystem 1 - Part No: 1J2959802C
   Component: 5X Tõrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J2959801D
   Component: 5X Tõrsteuerger. BF0002r
1 Fault Found:
01483 - Control Circuit for Rear Lid Remote Unlocking
            25-10 - Unknown Switch Condition - Intermittent
Address 56: Radio        Labels: 1J0-035-18x-56.lbl
   Part No: 1C0 035 180 E
   Component:  RADIO 3CP         0001
   Coding: 06411
   Shop #: WSC 00066
   VCID: 1A3B8F42865DFCEE9F-4B00
No fault code found.
End-------------------------(Elapsed Time: 05:13)--------------------
Then if i unplug the AirBag module, i only have the airbag light on, the tach works again, no other warning lights.
this is the auto scan
Code:
Saturday,26,December,2015,12:36:55:49733
www.Ross-Tech.com
Mileage: 174930km-108696mi   Repair Order: dec26 no airbag
Address 01: Engine        Labels: 06A-906-018-AEG.lbl
   Part No: 06A 906 018 JQ
   Component: 2.0l R4/2V  MOTR AT V01
   Coding: 00033
   Shop #: WSC 91471
   VCID: 7AFBAFC2661D1CEE3F-4B00
1 Fault Found:
18044 - Powertrain Data Bus
            P1636 - 35-00 - Missing Message from Airbag Controller
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 01M-927-733.lbl
   Part No: 01M 927 733 HM
   Component: AG4 Getriebe 01M    4544
   Coding: 00012
   Shop #: WSC 123456
   VCID: 020BD7220ECD542E67-095E
1 Fault Found:
Address 03: ABS Brakes        Labels: 1J0-907-37x-ABS.lbl
   Part No: 1J0 907 379 P
   Component: ABS     20 IE CAN  0001
   Coding: 13504
   Shop #: WSC 00066
   VCID: 3E7363D23AB5F0CE43-4B00
   Coding: 02312
   Shop #: WSC 00000
1 Fault Found:
   Coding: 00007
   Shop #: WSC 91487
1 Fault Found:
   Coding: 00257
   Shop #: WSC 00066
   Coding: 06411
   Shop #: WSC 00066
   VCID: 1A3B8F42865DFCEE9F-4AE8
End-------------------------(Elapsed Time: 05:01)--------------------------
ground to airbag module is good. power supply on pin t75/26 is good, check gry/wht white to instrument cluster-good.
i unplugged ABS module and still cant connect to airbag module.
fuses on battery box are good. checked all fuses in fuse box inside car. good.
the car starts and runs ok but is in limp mode because of Airbag fault
the previous owner had the front bumper apart to replace rad. no sure if maybe a crash sensor is hooped. but that wouldnt crash the module.
any ideas? or is my assumption that the airbag module is fried logical?
Discussion Starter #2
also, this car has been sitting for while with no battery before i bought it. and the radio fuses were blown. one behind the radio and the fuse box. and i just replaced the right front abs sensor. the ABS code 03504 shows the car as a all wheel drive, i changed it to 13504. (not sure if thats the right code or if thatis the code that changes info that the car is front wheel or awd???)
