Is this normal? When the car is idling, the voltage coming off of the alternator measures between 11.xxV and 13.xxV as i cannot get exact numbers as they change quickly. As the engine is running, there is an audible pattern during the idle, like a small RPM change during idle and those numbers change along with the same audible pattern of the idle. Should this be a constant or no?
