Found a couple of threads discussing this subject but not one exactly.
My daughters 2002 NB's fan works on position 1 and the a/c light is on. On position 2 and 3 the ac light goes off and the fan does not operate, on position 4 the fan blows hard but the ac doesn't come on.
Thanks for yall's help on everything from new door panels to blend door fixes!
blower
I think you are referring to the blower motor. Check the resistor pack connection that's under the dash on the passenger side next to the blower. You'll have to remove the glove box out to see it.
Not too bad of a job just a bunch of torx screws. I believe there is a diy around here with pictures and all. good luck man.
Thank you, I have seen that on other DIY's but I was afraid to go off in the wrong direction. I had the same problem on my Sebring.
selectro knob
could also be your selector knob not making good contact since all you're doing is selecting a different resistor when you turn that knob, and you know where that resistor pack is at. good luck.
