My 16 yr old daughter recently purchased a 2004 Beetle Convertible which she save up for for 2 years. The fuel door wont open.. We do the pry the credit card trick. When the door is open the switch works and the tab releases. However, it seems the spring is broken. So I went to the dealer and there are in fact 2 different springs you can buy for the fuel door. And they had no idea how they go in. Has anyone fixed heir door by changing the spring? If so, which spring and how did you replace it?? Thank you
