I'm a licened mechanic but havent much vw experience,
my wifes aunt has a 2001 beetle, 2.0l manual azg code
its been all over her hometown for a no start condition,
she got fed up with paying for nothing,
so far theyve put new coil (could of been cracked)
new fuel pump assy, plugs, wires, fuel pump relay.
heres what its doing,
it has spark, it has fuel pressure
the EPC light is on
it has no power at the injectors
no power at fuses 32, 34, 43
its also throwing codes P0223 throttle pedal position sensor
P0638 throttle actuator control range
P0118 coolant temp sensor
I do not have a VAG com, i could buy if i have to but other than her car i dont know if i would use it too much.
I do have a matco scanner
it will not run at all right now
I did buy a subscrition to alldata (for wiring info)
key on engine off the data stream is saying the throttle is at 62% and the coolant temp is at -40
so i'm thinking its missing some power some where
and im getting a little lost/frustrated
so really i am truly sorry if this is a dumb newb question
but i really do appreciate any help you could give me
thanks in advance
the EPC light is on
thanks in advance
