Hi everyone. Im new here but Ive been searching and searching and Ive tried numerous things I found here and appreciate all of the info, but Im stumped. Ive got a 1998 Beetle with an overheating problem. Technically, the fans are not coming on but I think its because the temp sensor is not getting hot enough.
Ive replaced the radiator, hoses, thermostat(2x), FCM(2x), fuse block on top of the battery, both fans, coolant temp sensor(in radiator). The fans come on with the AC and I can jump the harness for the temp sensor to make the fans work both low and high. The lower coolant hose is much cooler than the upper, even after the thermostat is open. I have a little IR temp reader that tells me that the lower hose is 120ish and the upper is 160ish (When the engine block is up to 190-200...so open thermostat). The thermo switch reads around 130 degrees before the tank starts boiling. The water pump doesnt spin by hand, it turns when I crank it, and all of the blades look fine. I have plenty of water coming out the return hose when I rev it up and the hoses get hard too so it seems like there is plenty of pressure. Miles are 106 and I think its the original water pump so I know its due but its seems to be working correctly.
If I unplug the thermo switch in the splitter thing on the drivers side of the motor the fans shut off (the fans work with the ac on) and my meter tells me that there is continuity on the switch so it seems to be working correctly. All of the wiring for the FCM and thermo switch test correctly according to what I could find.
So Im stumped. 2 things I was wondering...1. What is the sensor farther back on the splitter with the 4 wires and could that be the problem 2. I think the coolant tank cap is bad, could that be it? What tests should I do next? When it idles, it seems that the coolant return line is gargling, then when I rev it, it takes 5 seconds or so to spit solid. Could it be pulling air from the cylinder(Bad head gasket??)
Any input is appreciated. This thing is driving me and my wallet nuts. Thanks
