my turbo is bigger!!!!!!!
this time i snaped the drivers side motor mount/trany mount what ever u wanna call it.... i think the 6 pluck is causing all of this... oh well here is a pic... 2 down one more 2 go
Yeah, that's deffinately from the combination of the race puck and the non-race motor mounts. Swap all 3 mounts for better ones. I suggest going EIP or ZF-Engineering at all 3 points. And you'll probably need new bolts now too, that's some hella stress you've put on those bolts. You'll be amazed how little the engine will rock with those mounts in place.
For what you're doing you might want to install an engine damper too to try to smooth out some of the shock from launches.
Heh, any guess what your next weakest link in the equation is? ;) I hope you've already changed your axles....
yup got soem axle shop axles lined up
and a big HELLS NO to EIP... after seeing their posts and responses to customers with problems over on Vortex, EIP will never see a dime from me.
ive never liked eip.... i do everyting custom or like ecs lol...
