Water pump?
That's what i thought of too,Change timing belt water pump and replace the thermostat for good measure.Hopefully that solves the boiling out problem.Then start on the fan problem. Ill do the thermostat myself but replacing timing belt water pump i'll have to find somebody?Water pump?
Read your posts,Thanks very helpful I've have no smoke coming out of the rear exhaust.So when i take it in I'll have them do a compression test on the cylinders.If there all good water pump and timing belt. love the dancing bananas!I concur, water pump or head gasket and I am leaning toward the head gasket.
You are welcome, glad I could help out.Read your posts,Thanks very helpful I've have no smoke coming out of the rear exhaust.So when i take it in I'll have them do a compression test on the cylinders.If there all good water pump and timing belt. love the dancing bananas!I concur, water pump or head gasket and I am leaning toward the head gasket.
