i just bought thoses lock buttons that goes on the inside of the doors...
how to remove the older ones and replace them....
i just don't wanna break anything and have to add more cost...
i have a new hood, rear bumper side skirt and rear window wing to have painted and installed....
The lock pins?
Put an old towel over the pin, and use pliers to remove. Just be careful not to scratch anything. :)
-Des
New Beetle Accessories
On top of the factory door lock knobs you will see a small dot. The dot should be toward the window. For the driver's door you need to rotate the knob 180 degrees counter-clockwise. You can then lift it off. The passenger side needs to be rotated 180 degrees clockwise - then pull it off. Aftermarket or the aluminum Turbo "S" knobs can then be screwed on in a normal fashion until they are tight.
Hope this helps!!!:D
