i think we have a resonator thingy btwn our CAT and muffler. I hear the OEM TDI center exhaust pipe is a direct fit replacment for our center pipe but it doesnt have a resonator. so:
- is it really a direct fit, can it be done with jackstands and hand tools?
- does it increase performace?
- will the car pass inspection?
seems like this could be a cheap perf mod. any help is appreciated.
MkV Pilot
Plenty of people have replaced their resonator with a TDI midpipe or just a length of straight pipe.
I don't know how much of a direct fit the TDI pipe is. Try searching on www.vwvortex.com
It will increase performance a little bit. It'll help the turbo spool faster because there is now less restriction in the exhaust. Faster spool = earlier power
It will pass inspection. You have not tampered with the emissions equipment in any way, so you'll be fine
I say go to a local exhaust shop and tell them to cut out the resonator and weld in a straight pipe. Probably cheaper then going with the TDI pipe from the dealer with the same result.
thx. i'll be doing this this weekend. does it increase sound or vibration at all or a lot?
