I got mine used from a friend of psalm.
They're Goodridge. I believe Tire Rack sells this brand. Neuspeed also has a decent set. 'bout $100 I imagine.
Not sure if you can use Golf/Jetta parts on this one or not. If they're 4 line kits I would imagine you could though.
To bleed the brakes 1 person pump pump pumps up the brakes; 5-10 pumps and you should feel the pressure build up some... apply SOME pressure to the pedal and tell the person working the bleeder screw 'open'. They'll open the screw (w/vac line attached to drain into a glass jar) and as soon as the pedal pushers foot hits the floor, they should yell 'close'. Person closes the valve; pedal pusher ... pushes a number of times... builds pressure, tells screw operator 'open'... repeat about 40-20 times.... Start at the rear passenger wheel. Then the rear driver wheel. Then front passenger; and finally front driver. Don't ever let the resevoir run dry or you'll suck in air and have to START ALL OVER. I suggest you scoop out some of the old fluid from the resevoir so you don't have to pump pump pump pump your way through the whole tank. The trick is to not have the screw open w/o pressure on the brakes. So get a full pedal press.. but stop as soon as that thing hits the floor.
Bleeding just takes like a 10mm?14mm? wrench, a short fuel/vacuum line, a container, and a liter of fluid. It's not hard, but can be tedious. I've even bled the brakes w/the wheels still on the car.
