M16S VW & VW53HRB
My locking wheel nut adapter has broken! I have no idea what make it is, and seeing as my Bug used to live in America, I wondered if you guys knew! :)
Obviously the adapter's not supposed to look snapped, and the bolt not mangled, but you get the idea!
I've got 2 of my alloys 'stuck' on Robbie with these locking bolts, and I need to find who made the adapter so I can get another one!
*Lucy*
M16S VW & VW53HRB
Yeah that's one of the options - we were hoping to not have to resort to that tho.
I have a nice shiney set wating to go on, I just need these ones off - I'm paranoid that I'll get a puncture!
The local VW stealership removed that one cos we'd put on 3 of the 4 new alloys onto the Bug when the adapter snapped - so I had to drive 8 miles with 3 18in wheels and 1 16in with 3 low profile tyre! It was interesting! ;)
Thanks,
*Lucy*
180 Degrees out of faze
The first question should be, are these aftermarket or VW lug locks? If they are VW, the dealer can just order a new one. The choices are to use Tom's method of pounding on a socket, or grab the lug with a large pair of channel locks.
M16S VW & VW53HRB
Been to the dealer - they'd never seen them. I have found out where they come from tho - it's a car accessories chain in the uk! So hopefully I can find a set now that I know where they come from :)
Thanks,
*Lucy*
Find a mechanic with a set of stud extraxtors. One the right size should be able to slip on your stripped bolt and grab it so it can be removed.
M16S VW & VW53HRB
Discussion Starter · #7 ·
I think that's what VW took this above one off with. My bf is trying to make something to undo it with - but if that fails, we'll pop down to the tool store and get some of these.
