When we got our Beetle about 3 month ago, the AT indicators(which tell if you are in P, R, D,etc) did not light up on the shift cover. I took it apart, and carefully straightened out the electrical strip, which lights up the indicators. I put it back together, and all seemed fine. The other day, while driving in a light rain, I noticed that the indicator lights on the AT cover were flickering. When I would tap the cover, the lights would brighten up. Now, the indicator lights again are not working.
It appears to me there is a loose connection somewhere. Is there a ground connection? Where is the wire connector end of electrical strip located? Does the wire go forward or backward from the cover, so that I can attempt to locate the connector end
Any tips or pointers would be appreciated.
