Yes the title is correct. I am putting together a grand trip thru 8 countries and hope to end up in Panama. Two of the countries are quit wild to say the least.
Since "Ole Yeller" is down for the new timing belt and head job, opps can I say that, I thought I would really take it apart and prep it for this new life adventure. I am going thru about everything on the car and upgrading or renewing it.
This thread will follow the build out and the trip thru these 8 countries. Southern USA, Mexico, Guatemala, El Salvador, Nicaraqua, Honduras, Costa Rica and Panama. The start date will be when I have completed the build out and am satisfied that all is ready.
The trip down will be done on one, yes one, fill-up of bio-diesel. I personally will make the bio-diesel so I know it will be correct. That tank will consist of 100 gallons of fuel,on a trailer, plus a full tank in the NB. So no stops for fuel just eats and rest.
I will literally start at the top of the car and work my way down. New headliner and new antenna to receive AM/FM/CB and GPS/WiFi. Going to try to keep it as non-discript as possible. Try to not attract much attention if possible. One country is in the top 10 for Americans to not be in. From there the interior will get some upgrade to the drivers seat. Then a new A/V system will be installed with moving map ect., plus front and back viewing and recording cameras. New windshield and then to the exterior.
I now have VR6 suspension with Audi TT 312 mm brakes but hoping to upgrade to an air bag system on all four corners. The LCAs will be swapped out for Audi TT as well as the steering knuckles, with new bearings and ball joints. New 108 mm axles and u-joints of course.
I will be cleaning up the casting on the head for better flow and cooling. New valves, guides and a regrind. Thinking about a Frank06 stage 2 cam, but not sure yet. I have an new hybred oil pan I will be installing also, with a new oil pickup. New A/C compressor and a new radiator as well. All new hoses and belts of course with the new timing belt kit. Also may use a fluid harmonic balancer, doing research on that now.
I am now running several mods, engine wise and have 55 watt HIDs installed.
I have a small boat trailer that I will be modifing for the trip. It will hold the fuel and the supplies that I may need along the way. Of course extra parts and tires. I will be installing a trailer hitch on the NB also.
Lots to do so follow along as I will be showing all of the build out and the trip in this and several other forums.
Happy times are here again...... I love being retired finally.
Richard55
Richard55
