i have a 2000 beetle with a blown auto box code DYQ,CANT FIND A SECOND HAND ONE,CAN I FIT AN ELZ from a golf?if so what problems might i encounter?thanks
2001 2.0 Manuel has trouble shifting into fifth gear. if your lucky you can get it to go but its not like it should be. anyone know if this is a sign of a bad tranny? what else could it be?
I bought New beetle 2000 , 2.0 automatic transmission. it has problem with transmission.. it's in 3rd gear ( I think ) .. speedometer works well, tachometer not and oil check ( I changed oil but still check) . I changed G68 sensor also and diagnostic says "no communication from TCM" .. what I...
Hey all. Well, I dove into the beetle world with (2) 2003 beetle convertibles.
I am using one as a parts car.
Main one is 2003, 2.0, triptronic 09G. I'm trapped in limp mode because the TCM isn't communicating with the ECM or the Instrument Cluster (confirmed by the OBDeleven). Also with no...
