I recently purchased a 2000 Beetle (2.0l auto) and from what I can tell it never shifts up to 4th gear. When in Drive, it does 80kph at 3000 rpm, 100kph at 4000rpm (or a smidgen under 4000), and 110 at about 4200 rpm. Do those rev counts that sound too high to you?
When cruising at 100kph, if I move the gear lever back from D to 3, it makes no difference - there is no downshifting.
If this does show a problem with the transmission system, is it a known/common problem?
With thanks,
Matt.
With thanks,
Matt.
